Zum Hauptinhalt wechseln
Anleitungen und Reparaturhilfen für Küchengeräte von KitchenAid.
20 Fragen Alle anzeigen
No power after replacing a bowl lift
Hi ifixiters
I have a Kitchen Bowl Lift Stand Mixer (European version). Model number 5KSM7591.
The bowl lift got damaged and needed replacing, so I bought a replacement. I thought I needed to remove the motor but after removing the cover I realised that wasn't the route. I may have unplugged a cable connection that sits next to the fan but reconnected it.
I then removed the base and installed the new bowl lift without disconnecting any of the cables.
The mixer now does not turn on. I have changed the plug in the fuse, and checked the socket and tried other sockets.
Any thoughts on what may have gone wrong? Is there a fail safe connector or something that I'm not aware of?
Thanks in advance
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If it wasn’t broken before you fixed it, then it’s something you did. Go back in and reconnect again what you took off. Do not have it plugged in while you do this.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you Mayer for your response.
I checked every connection but everything is connected and solid, so I really cannot understand it.
von
Antwort hinzufügen
Will A wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 94
