Blank screen with sound
No picture but still there is sound
Ist dies eine gute Frage?
James t.j start by taking a look at the screen with the TV on in a dark room. If you see a faint glow on the display than you know that your beacklight is on. In that case my first suspect to replace would be the T-con board. If the backlight does not come on, then I suspect the power board. Unplug your TV and remove the back. Check the boards for any suspicious looking components like domed or leaking caps. The issues here has to many possiblities that can not be ruled out unless you do a little bit more troubleshooting. First verify that your TV is a UN60FH6003FXZA then let us know what you already have checked. Try all the differnet inout sources and see if the results are the same. If so you will have to look at the boards. you can always post some pictures of your boards with your question so that we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that
War diese Antwort hilfreich?
here's a link to a similar issue that you are experiencing. The solved answer should provide you with the answer to your issue! If not, let me know and I can try to further assist.No picture but there is sound
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 484
