Zum Hauptinhalt wechseln
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
56 Fragen Alle anzeigen
Upgrade 9550 battery with 98Whr version?
Hey I own a Dell XPS 9550 with the 54Whr battery. I have very sub par battery life and have already replaced the battery with minimal improvement. I am considering upgrading to the 86Whr battery from the same model (I understand this removes the SATA drive) but have seen 97Whr batteries from later models. Will these fit in the same area or are there other changes to these higher capacity models that mean it will not be compatible?
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yes, its safe but make sure as long as its output voltage & current values are same. Output voltage has more importance as higher voltage can damage your laptop. and the battery size must be same
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Callum Cooper wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 474
