Zum Hauptinhalt wechseln
Die Nintendo Switch ist eine tragbare Spielekonsole, die auch mit dem Fernsehgerät verbunden werden kann. Sie wurde am 3. März 2017 veröffentlicht.
707 Fragen Alle anzeigen
No HDMI to TV using Nintendo Switch Dock after USB-C Port Replacement
Switch had a damaged USB-C port with broken pins. Replaced the USB-C port with a new one and now it charges fine and everything works great except for the Nintendo docking station to output to HDTV.
When I connect the Switch to the dock, it does receive a charge through it and the green light to indicate it’s outputting to an HDTV lights up, but no image or sound is produced on the TV.
I have already gone through Nintendo’s official troubleshooting steps with basic things like trying other TV’s, other HDMI cables, etc. I have tried different combinations of the order in which I plug the cables into the dock before I actually connect the Switch and none of that has made any difference. In fact, according to Nintendo, if I am getting the green light on the dock but there is still no image displayed on the TV, then I should send it in for repair. Heh.
So rather than drop close to $90 for an official Nintendo dock or $40 for a third-party dock, does anyone have any other suggestions? Is there any way to go about troubleshooting the controller board inside the docking station? Could the USB-C port I used to fix the no charging issue due to the damaged pins be to blame? Could the damage to the original USB-C port have caused other damage to diodes, resistors, ICs?
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
To anyone else facing this issue - Go back and check your soldering job on the USB-C port. The lower row of pins on the port was to blame. One or more of them may not have been soldered properly.
War diese Antwort hilfreich?
Bewertung 6
1 Kommentar:
If the above doesn't solve your problem, further troubleshooting steps are available at the following link:
https://repair.wiki/w/Nintendo_Switch (scroll down to No image on Dock/TV)
von
Antwort hinzufügen
TechWizard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 49
Insgesamt: 8,930
