Zum Hauptinhalt wechseln
Samsungs Flaggschiff-Smartphone, das Galaxy S8. Erschienen im April 2017.
Remove Verizon Boot Splash Screen
Hi,
I upgraded my S8 to a S9 and would like to sell my old S8 as an unlocked device.
I was told that being that the phone is paid off, It is unlocked, and can be used on any carrier.
This is great, but am wondering how to remove the Verizon Boot Splash screen and the pre loaded Verizon applications after the device is reset.
If I were to buy an unlocked phone and were to use the device on a different carrier, I wouldn’t want the Verizon bloatware on my device.
Is there any way to get the stock android firmware on the device. As if it was bought directly from Samsung?
And if not, do you have any suggestions for the best way to go about selling it as an unlocked phone with all the added Verizon crap?
Thanks,
Taylor
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Verizon phones will not accept any custom ROM. This has been done this way since the S4/Note 3. The way Verizon locks their bootloader effectively prevents other ROM’s from being installed - even the reference Samsung ROM from the Unlocked by Samsung series. AT&T is also guilty of doing this so Verizon isn’t alone. IT HAS to be the carrier specific ROM or it prevents it from BOOTING.
The feature Verizon uses is known as Samsung KNOX. They use boot signature enforcement, which verifies the ROM signature against the “correct” signature. The phone will not boot without the Verizon ROM installed since the signature varies per device (Unlocked, T-Mobile, AT&T, Verizon, Sprint). The KNOX “feature” prevents you from removing the Verizon ROM or modifying it to remove the bloatware. Root can be used to "force” it off, but you cannot change the ROM to remove it permanently, but it triggers the 0x1 flag and permanently disables Samsung Health.
How I’d sell it is I’d sell it as unlocked for any carrier, but explicitly mention it’s a Verizon phone. This is sufficient because while it’s SIM unlocked (FCC open network license requirement), it is still a Verizon phone. It will also deter buyers who want the ability to tinker with the ROM, so you will not need to worry about the KNOX 0x1 flag being tripped and hurting the resale. You are better off losing a sale from someone who opposes Verizon’s lockdown practices to avoid getting a tripped phone back.
War diese Antwort hilfreich?
Bewertung 9
9 Kommentare:
I figured as much :/
Hopefully the buyer won't mind!
von
Yeah... There's a reason that the AT&T/Verizon phones are unwanted (or strongly disliked) by buyers who care about the ability to tinker with something they own. It doesn't bother everyone, but buyers who want the freedom to tinker with what they have will overlook them entirely.
The problem is if you're on Verizon, you can't use a tinkering friendly model unless the IMEI/ESN range is in their system. They don't like to approve phones that aren't locked down for that. I've added my advice to the answer.
von
If you buy a phone direct from let's say Samsung and use it on Verizon's network do they still use their boot rom forcing their splash screen on your device, and is it then un-removable in that case?
von
@Gordon No - this only affects the Verizon V/VZ 5G SKUs (Ex: SMG781VZBV). However, today they're using 5G to force people to buy branded hardware because they use a 5G band literally nobody else uses.
I'll pass on 5G until everyone stops using it as a circlejerk to break cross compatibility. Not much faster, more expensive plans and broken carrier cross support... I'll let people beta test the future incompatible devices and buy in when the bands are known (especially the FU for buying from anyone else like the Verizon UW one).
von
I guess you can remove not just bloatware but anything from any cellphone with a Pc, Minimal ADB and Fastboot installed on it and app inspector on the phone.
von
4 weitere Kommentare anzeigen
So my factory unlocked Note 20 Ultra that I bought directly from Samsung will permanently have Verizons stupid boot logo forever?
Bewertung 1
4 Kommentare:
my samsung, now on AT&T appears to eb stuck with xfinity mobile splash etc.
von
It can't be removed so I bought a new clean one and smashed the Verizon phone to smithereens. Total BS thuggishness outta Silicon Valley. Plus Verizon condones the Chinese licensing. Boycotted. Shut it all down!
von
I went to mobile with my verizon phone, installed their Sim and it changed the splash screen to mobile, since mobile does not lock you out, I went home and flashed a cusstom boot screen. that is the fix, also if you have samFw you can change the csc to xaa and it will allow the boot screen to be changed
von
t-mobile, sorry my phone did an auto correct after I hit post
von
Antwort hinzufügen
Taylor Struna wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 58
Letzte 30 Tage: 168
Insgesamt: 37,449
