Zum Hauptinhalt wechseln
The first generation Honda CRV, produced from 1995 to 2001.
97 Fragen Alle anzeigen
Back up light switch location
Hi guys,
i hope you’re all well!
Im having issues with the back up light switch. It needs replacing. Apparently I can not find the exact location. The engine is 2.0 liter 147 hp manual transmission. If anyone can share exact location or even photos that would be great!
Thanks in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I think it’s the one on the darkest photo?
von
Hi @stoyanr
Your pictures did not show up.
Try posting them again in your question above. Click on Options > Edit > in the Question description bar click on "insert image" icon and follow the prompts.
Alternatively see the link @oldturkey03 provided below
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi again guys!
Thanks for the help!
I found the bastard, it’s located right under the air filter plastic housing. Just unscrew the two bolt on the top of the housing and the unplug the air intake hose.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Hi @stoyanr ,
See the Most Helpful Answer in this link
Why my reverse (backlight) won't work?
Bewertung 1
5 Kommentare:
Hi, I went through this topic but still struggling to locate the exact location.
von
@stoyanr it is located on the transmission housing. If you are unsure, take plenty of good pictures of your transmission etc. and post those with your question. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that. We most likely can point it out to you. What is the exact year of your CRV?
von
Hi @oldturkey03,
Thanks for the recommendation. Once I get back home I’ll take photo and post them here. It’s 1999
von
Is it on the top side of the housing or on the bottom side? Shall I go underneath the vehicle?
von
@stoyanr it should be on the top half of it. I don't think it will be underneath but it will never hurt to see to much.
von
Antwort hinzufügen
Stoyan Stoyanov wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 35
Insgesamt: 2,778
