Zum Hauptinhalt wechseln
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 Fragen Alle anzeigen
I got Coke in my 2ds. How do I fix it?
I had it in a bag and Coke got all inside the DS. The light will come on, but, nothing will show up. How should I fix it if we don’t have the alcohol for it? Also, will GameStop refix it if I say it was an accident and I really did try to take care of it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Tʜᴇ Pᴀᴄɪғɪꜱᴛ • Wɪʟʟɪᴀᴍ Vᴀʟᴀᴅᴇᴢ  if by Coke you mean the soda, you will have to clean it and quickly. Disassemble it by using something like this guide Nintendo 2DS Hauptplatine austauschen Then clean every bit of it in 90%+ isopropyl alcohol. Use something like this guide iPhone Wasserschaden reparieren to clean it. Even so it was written for an iPhone, the cleaning process is the same. Once you have it properly cleaned, replace the battery and then re-evalaute for any further damage. The longer you wait the greater the chance of corrosion from the acid and sugars involved with your soda.
iPhone Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
Nintendo 2DS Hauptplatine Bild
Anleitung
Schwierigkeitsgrad:
Mittel
30 - 40 minutes
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 137
