Zum Hauptinhalt wechseln
2.4GHz, 2.7GHz, oder 2.8GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
274 Fragen Alle anzeigen
MBP Stopped Charging, No Mag Light
Just today, our MacBook Pro (15” Early 2013) stopped charging. I have tried two Apple Magsafe 2 power supplies with the same result. Neither lights up on the power supply connector, and there is no charging indication for the battery in MacOS.
For the last year or so, the battery has reported “Service Soon” or something similar. It doesn’t last long and is probably on it’s last leg.
Is the charging issue related to the battery or is this associated with internal electrical hardware?
Is the logic board responsible for the Magsafe operation and battery charging, or is there another electrical assembly that does this? I’m wondering what should be replaced - logic board, battery, or something else?
Below is an screenshot from coconutBattery.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
If the battery tells charging ic that its not safe to get charhed then sequence getting stopped. Try battery replacement first and then if its same thing post your logic board number
War diese Antwort hilfreich?
Bewertung 0
hello,
do you see green light all the time and won’t turn into red ?
Bewertung 0
Antwort hinzufügen
Jimmy M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 51
