Zum Hauptinhalt wechseln
Der Xbox Wireless Controller 7MN-0001, hergestellt von der Microsoft Corporation, ist der am meisten für die Xbox Spielekonsole verwendete Controller, der auch für PCs verwendet werden kann.
127 Fragen Alle anzeigen
How would I fix a loosened micro usb port on an xbox one controller?
so when I plug a micro usb cable into my xbox one controller, the port on the controller would wiggle when touched and would barely power on the controller. If the controller were moved slightly, the cable connected to the controller would turn off the controller until it’s placed on a flat surface.
I think I caused the problem by accidentally dropping my controller while my cable was plugged in.
with that being said, is there any solution (besides buying a new controller) that can help?
Thank you in advance for the responses
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Use long rubber band to somehow make an X shape in middle of controller. Might need to carefully adjust the rubber band until it loops around the neck of cable
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @dvorak ,
If the USB port is only loose and the pins aren’t damaged etc, then most probably all that is required is that the USB connector be resoldered back onto the motherboard.
Here’s a link to the ifixit Xbox One Wireless Controller untere Platine Austausch guide.
If you click on the 1st image in the guide you see the USB port at the top of the picture.
Once you have access to the motherboard it can be resoldered back on.
You’ll need SMD (surface mount device) soldering skills and tools to effect the repair.
If this seems too daunting, take the motherboard (handle gently) to a reputable professional electronics or mobile phone repair service and ask them to do it for you. As you have already dis-assembled the controller (and will re-assemble it yourself ) this should minimize the cost of the repair. Also SMD soldering is not that easy if you’ve never done it before. You may cause more damage than what you had it the first place.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Josh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 25
Letzte 30 Tage: 129
Insgesamt: 22,719
