Zum Hauptinhalt wechseln
The Dyson V8 Absolute can be identified by its model number: 214730-01. It’s a cord-free, hassle-free vacuum released in April 2016. The Dyson V8 Absolute comes with HEPA filtration and up to 40 minutes of the most powerful suction.
bin/canister will not open no matter how hard we pull
I cannot open the bin/canister of my Dyson V8 Absolute to empty the contents. The trigger does not budge. We tried the little red latch on the bottom of the bin/canister but it’s blocked. We cannot detach the canister as the top red trigger is blocked. I bought it in June last year so still under guarnatee. Dyson told me to send it to them, which I am reluctant to do.
Any ideas how to open it without destroying it? It’s been a week of pulling the trigger so really fed up at this point.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
OK Folks HERE is the the real solution, All the other posts do not address the actual CAUSE which is a manufacturing/engineering defect.
inside at the bottom of the clear canister is a raised center, button type thing, this fits inside the black tube coming down from the power head. when new it slides in and out when opened or closed. Over time and use this becomes scratched and rough causing it to BIND. It may open and close ok once forced open BUT, after using the vacuum it gets sucked in tighter and will not release. I analyzed the problem and came up with a permanent solution. you need to reduce the interference on these 2 parts, using 90 grit (course) sandpaper to remove material on the OD and ID of both parts. after 90 grit paper repeat with 200-250 grit then you Must use 600 grit to polish and smooth, failure to do this the surfaces will be too rough and still bind. YOU MAY NEED TO REPEAT this full process several times until enough plastic has been remove for it to release freely.
Trust me on this!!!!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Dolly wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 382
