Zum Hauptinhalt wechseln
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
Where to find compatible front wheel nut in France?
Hi, I lost one of the front wheel main screw nut.
Replacement nuts seam not to be available in France: the thread way thinner than the provider one (size M12 anyway).
Do you have any idea of where to find compatible screw nut?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Same problem for me!
The nuts is M12 x1.25
I found it in a big screw seller.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Care to give a link?
von
Hi stefano, I just received my nuts M12 x 1,25 mm and it works 100%.
Many thanks a lot for your response and help!!!
von
Hilfreichste Antwort
Have you tried taking a wheel nut to your local hardware store or automotive spare parts. Many parts that are on bicycles are interchangeable with other vehicles/hardware.
i found some here https://www.toolstation.fr/shop/Screws+%...
but I’m not sure if this is the exact part you are looking for.
Bewertung 2
1 Kommentar:
Thanks for your helpful answer. I found some on an agriculture website and it works just fine: https://www.agriconomie.com/ecrou-autobl...
von
Take a look at step#7 of this guide and see if this the the nut you are referencing:
Xiaomi MiJia QiCycle E-Faltrad Teardown
Bewertung 2
Antwort hinzufügen
Marianne Laurent wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 469
