Zum Hauptinhalt wechseln
A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
24 Fragen Alle anzeigen
Model PSX3 tire inflator won't turn on, other functions have power
PowerStation model PSX3 has both tire inflator and jump starter functions. It also has a work light. The inflator had been working fine, but now the push button switch has no effect. Seems as if an electrical connection has been broken. The work light functions perfectly, so there is power available. Inspection of the interior wiring didn’t reveal anything obvious.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
my PSX3 compressor has started to run very slowly put-put-put...can that be fixed?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
david barkman  it sounds like a bad switch (mechanical failure). If you can disassemble it, check the switch and you could always try to replace it. We would need to see what it all looks like in order to give you more details. You can always post some pictures so that we can possibly provide you with a more precise answer. Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Everything works on mine except it doesn’t seem to charge. Light works and compressor works .
Have stripped it down and found a capacitor and resistor burnt out. Can see the capacitor values but there is no way of reading the resistor value. Any idea where I could get a circuit diagram please?
Thanks
von
Antwort hinzufügen
david barkman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 27
Insgesamt: 1,479
