Das HP Pavilion x360 15-bk020wm ist ein 15,6-Zoll-Laptop mit Touchscreen. Es verfügt über das Betriebssystem Windows 10, einen Intel Core i5-6200U Prozessor, 8 GB Arbeitsspeicher und eine 1-TB-Festplatte mit 5400 U/min.
Spilled half a bucket of hot water on it what do I do!? How can I fix
I am a 13 year old and I have a mom who would kill me if she found out that I spilled half a bucket of hot water on my laptop so please help me!!!! What happened was I woke up at 3 am to boil some water for a cold I had and when carrying the bucket of water I left it on a small stool (tiny chair) with my laptop on the ground (where I left it last night because I fell asleep) So i went to the kitchen for a brief moment only to arrive and see the water spilled all over and some of it went into the laptop. I tried turning it on but it didn't work, and I unscrewed it so that I can get the battery and hard drive out but unfortunately I couldn't remove the chassis and I can't ask my mom for her blow dryer because she would ask why and I can't tell her what happened. Please help me!!!!!!
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
You’re best bet is to tell her sooner than later and getting it out of the way. She’s bound to find out about it anyway.
The sooner that the laptop is properly cleaned and dried the better the chance of getting it working properly again
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the laptop’s operating design and could damage the components.
It is good that you have removed the battery already as this will minimise any further damage
You need then to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores and some pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and other ingredients and is not as effective. If you do check the label to verify the amount of IPA
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the laptop might possibly work correctly again.
Here is a link to the service manual which may be of some help in dis-assembling the laptop
If this process seems too daunting, take your laptop to a reputable, professional laptop repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
