Zum Hauptinhalt wechseln
Failed cooling of power supply
Replaced old power supply. Computer ran well for about 4 hrs after closing it up then the new power supply failed due to heat buildup. Suspect lost cooling air flow. Can a fan failure be the fan only or instead be a problem with the main board’s control of the fan?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
More likely the power supply still has the original electrolytic capacitors which are faulty!
What is the Great Capacitor Plague? And here’s a bit more: The Great Capacitor Plague of the Early 21st Century
War diese Antwort hilfreich?
Bewertung 1
Be sure that the fan is not clogged with dust and that the fan duct is clean.
You can also try to use Macs Fan Control to try and keep temperatures down inside your iMac if you determine that the fan and fan duct are clean.
iMac G5 20" Model A1076 Fan Duct Replacement
iMac G5 20" Model A1076 Left Fan Replacement
iMac G5 20" Model A1076 Fan Duct Bild
Anleitung
Schwierigkeitsgrad:
Leicht
iMac G5 20" Model A1076 Left Fan Bild
Anleitung
Schwierigkeitsgrad:
Mittel
Bewertung 0
Antwort hinzufügen
Don Jeffels wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 88
