Zum Hauptinhalt wechseln
Reparaturanleitungen und Hilfen für Samsung Fernseher.
2614 Fragen Alle anzeigen
Vertical Lines on Samsung LED TV
I have a Samsung TV (Model No: UA46D5500RR) which has now started showing vertical lines on the screen. The screen is just filled with those lines.
TV: Samsung 46''
I am also attaching the image below.
Update (11/06/2018)
My bad. Here is the image of the lines on my television.
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
you haven't attached a photo. are the lines moving or always in the same place? are they present on start up?
von
@pollytintop : The criss - cross lines are always there on the tele. they are visible from the boot till I close my tele.
von
I'm getting this issue as well too only mine are moving across the screen. They show up in my xbox dashboard settings they are very easy to see on the black and grey background. They are showing up a lot in the tower in destiny 2 and in the division 2 in some areas. They are thick dark vertical lines that travel across the tv. They are very transparent/faded.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Safal Verma  that could be an issue with either the T-con board or the main board. It will depend on what those lines look like. Use this guide Bilder zu einer vorhandenen Frage hinzufügen to add some pictures. As a general rule, if you press the menu button and you can still see your menu properly, it is your T-con board. If not then it’s your main board. It is not an exact diagnostic but it gives you an idea. Again, it will all depend on what it looks like since there is always a chance that this is a bad panel (unlikely unless it got damaged)
War diese Antwort hilfreich?
Bewertung 3
This problem is not the boards unless you are taking about the circuit board connecting the TCon to the panel with the COF tabs. The scan and discharge voltages may have changed due to component deterioration. There are ways to adjust these circuits by changing the bias on the ‘Ref’ pins. Sad that Samsung hasn’t sent out a solution to this problem.
Bewertung 0
I have it to it was a ghost imagine then it had vertical lines
Bewertung 0
1 Kommentar:
[image|2453310] see look at it irs so annoying omgggg
von
Antwort hinzufügen
Safal Verma wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 28
Insgesamt: 8,377
