Facing Problem on my calculator
My calculator is fully reversed. The number is reversed. Everything is rotated into 90 degree. How can i fix this problem?
Ist dies eine gute Frage?
Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
If you have not tried the reset sequence here it is…
(CLR)
(Setup)
(Yes)
Kommentare:
No.Still it's not working.I already did this work.My full calculator screen is reversed.
von tanni tanni
How's it going I'd like to try to help you fix your device so there's not a factory reset button on the back of it but you could try hitting shift 9 to enter the list then press 3 to reset all and then the equal sign to confirm it then hit the AC button to return it to normal then shift AC to turn it off reboot it see if it works like that then if that doesn't work you may try to take out the battery and getting a paperclip so the positive and negative terminals can reach each other that will help take out some extra electricity let it sit for 5 minutes then replace your battery
Hopefully that will help if not please let me know and I will be happy to continue finding things to help you out
Rep: 1
shift button is working only for offing the calculator not for other usages…
Letzten 24 Stunden: 9
Letzten 7 Tage: 47
Letzten 30 Tage: 209
Insgesamt: 2,136
20°56°its answer plz solve
von Zarmeen Alishba
