Zum Hauptinhalt wechseln
A series of 40 inch LCD HDTVs by Sony.
led panel vertical lines and screen blinking
sony led model no kdl-32ex650 panel replacement cost
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
This is a question for a local repair shop or manufacturer. This website is meant for fixing devices on your own. Unless if you’re asking where to find the part to replace the LCD?
von
Einen Kommentar hinzufügen
1 Antwort
chauthmal20  you did not tell us why you think a new panel will fix this. Replacement panels are often more expensive (if they can even be found) then a new TV. To find a proper replacement you need to go by the panel bumbner not the TV’s model number. Open up your TV. You’ll find a white sticker on the back of the LCD. It will say LG, Samsung, Sharp or whatever manufacturer made that panel and then the part number. Use that number for an online search.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
chauthmal20 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 216
