Zum Hauptinhalt wechseln
A series of 40 inch LCD HDTVs by Sony.
20 Fragen Alle anzeigen
schematic square box w/ lightning bolt symbol
Sony model KDL-40SL150 no power, just red light.  the power supply board has a burnt spot where the schematic symbol - square box with lightning bolt in it appears. is this just a fusible link and can I close the link for a fix?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
If there are burn marks on a power supply I typically just replace the entire power supply.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@franko1
We need to see what the board looks like to determine if the board is repairable and what part may have failed and why. post some images of it with your question Bilder zu einer vorhandenen Frage hinzufügen
Sometimes it could be as simple as just replacing a capacitor whereas other times the whole board may need to be replaced. again, we need to see it to be certain.
Update (11/24/2018)
Looks like a solder bridge and it could be multilayered board. You can try and close it by solder a jumper across. Make sure that your fuse is ok. worst case scenario it does not close the circuit since you may not get to the second layer of the board and can’t close the circuit.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Frank Jean wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 146
