Zum Hauptinhalt wechseln
The Bose 3-2-1 Home Entertainment System is a series of DVD-based home media systems in the Bose 2.1 home theater line. The Bose 3-2-1 Home Entertainment System was sold between 2001 and 2006 and was available in black and graphite colors.
Bose AV 321 Subwoofer Not Working.
Bose Service centre says the parts are not available in India hence can’t repair. Buyers of bose are passionate about sound, difficult to just give up.
The Bass Module stopped working after a short circuit but the speakers are working.
Who would be able to fix this?
Ist dies eine gute Frage?
Bewertung 4
5 Kommentare
Hi Puneet Rawat
What had you tried?
What issues you are having now?
like able to turn on but no sound?
von
Mine is well soldered but still no sound to the sub woofer except the smaller speakers only. What could be the problem? i have changed the TDA7396 twice now but no joy
von
Hi Puneet,
did you manage to fix this? I’ve got exactly the same problem. I tested all resistors and capacitors up / from TDA7396 and they seem to be fine. I also replaced the TDA7396 as you did with no sucess. I’m really lost.
Felipe
von
scusate il problema e di un chip siglato A3089G
sapete dove posso trovarlo?
von
checco70t: How do you arrive to the conclussion that the problem is with that chip? Also, where is this chip located? it's not displayed in the electrical part list in the service manual
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Puneet Rawat  this could be a Bass module issue on your Bose. Post some good pictures of the modules etc. with your question. That way we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that.
Here is the schematic for the module and you can start checking components with a multimeter. Let us know what you find.
War diese Antwort hilfreich?
Bewertung 3
Have you checked the fuse?
From Bose Troubleshooting guide:
”AC mains power is connected by the line cord via jack J1. A slow acting fuse F1 is connected between J1 [D7] and the locking primary connector J3 (or J2 or J4) to protect against faults. A Metal Oxide Varistor (MOV) VR1 is placed after the fuse and across the line. It is used to protect against lightning strikes and other line transients. “
I did some research and it sounds like bad solder joints are common in this unit, So I would look for any cracked joints, cold solder, etc. while you are in there inspecting the fuse.
Bewertung 1
2 Kommentare:
Mov VR1 do you know wich one can i buy
von
First you should use a meter to confirm that the part(s) is(are) bad. Start by re-flowing the solder to those parts. You can also short the fuse to see if it works, but I wouldn't recommend leaving it that way.. the fuse is there for safety of you and the device.
I found that part on tessco
https://www.tessco.com/product/suppresso...
von
ciao ragazzi io ho il problema uguale non va il sub il difetto e il chip A3089G sulla scheda madre del av3-2-1 potete darmi lo schema oppure sapete che sigla a questo chip? e dove poso reperirlo?
Bewertung 0
Antwort hinzufügen
Puneet Rawat wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 35
Insgesamt: 3,921
