Audio amplifier has short circuit
Hi,I am repairing an audio power amplifier…I don't see any damaged parts but the light bulb indicates that it has a big short circuit…its peavey cs 2000 power amplifier
pls help
Ist dies eine gute Frage?
pls help
Make, model and a few pictures of the boards inside would help. You give us little to go on here. In general, with a direct short like this, look at the bridge rectifier being shorted (if there is one) or if this has a switching power supply, check the main transistor (should be on a heatsink).
Update this with the above info and we should be able to provide more detailed suggestions.
War diese Antwort hilfreich?
I am unable to upload images but its peavey cs 2000 power amplifier
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,960
Is your amp repaired??
von Mallon Mbewe
Hi im roldan from cebu .my question is..what can i do the speaker out is bad tune ( mahina parang short ,)not fully higher tune.im using 1 channel only cause the other channel is broken .
Thank you.
von Kuya Reinz Bustillo
Hi @Kuya Reinz Bustillo,
What is the make and model number of the amp?
von jayeff
Ask ko lang po kung na short circuit yung amplifier means madadamay po ba yung speaker ? Salamat po
von Michael Geronimo
