How do I get the codes off my 1994 bronco?
I need to know how to get the codes off my 1994 bronco
Ist dies eine gute Frage?
This predates OBDII, so you can’t use a code reader. For OBDI vehicles, each manufacturer has a unique set of codes to identify faults (On Ford/Mazdas with Ford parts, it’s usually a CEL pattern or codes displayed on the dash cluster VFD). There is no standardization on OBDI vehicles so you need to see what Ford uses on the Bronco specifically. In some cases, the codes vary by one model year with OBDI. From what I can find, it looks like the Bronco uses 2 digit EEC IV codes.
Your best bet is to find a factory service manual with the codes, but I found a code list here if you cannot find the factory service manuals or can’t afford to get them. This site also has some information on the additional code sets Ford uses on OBDI vehicles and information on how to access and clear the codes once you’ve fixed it.
The problem is OBDI isn’t as clear cut to work with as OBDII, so some of my information may be incorrect. That said, short of finding a factory service manual the info I found is as close to it as you may get.
If it is new enough, give this scanner a look if the right plug is available: https://www.innova.com/collections/car-g... — not all OBDI platforms have the ability to use a OBDI scanner or an adapted OBD II but many do.
War diese Antwort hilfreich?
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 53
Insgesamt: 758
1 Kommentar
This question was migrated from https://meta.ifixit.com/Answers.
von iRobot
