Cat chewed through cable below volume control. Any way to fix this?
Cat chewed through cable below volume control. Any way to fix this ?
Ist dies eine gute Frage?
You certainly should be able to solder it, but soldering this type of ultra-flexible wire is a bit fiddly. See https://wiki.restarters.net/Headphones for some hints. You will need some form of strain relief so that tension in the cable isn’t borne by the solder joints.
War diese Antwort hilfreich?
It might be much easier to just buy a new cable:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 109
1 Kommentar
Hi. Maybe you could solder it but it won't be easy.
von Csendes Csaba
