Zum Hauptinhalt wechseln
Support for musical holiday decorations by Mr. Christmas Inc.
Not working at all
Nothing is working so disconnected the motor now the lights work with music. So I assume the motor is no good , is this so and can I get a replacement motor.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It could be that the motor or gears are jammed, in which case the stalled motor will take a heavy current, dragging te battery voltage down to a point where the lights and music don’t work. If you disassemble it you should be able to see whether the motor spindle turns freely or whether something else is jamming it. You may find some markings on the motor and if you search online you may find a supplier, almost certainly in the Far East.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Hi,could you tell me where I would find which ones I would need?.
von
Ok thankyou.
von
I have looked but carnt see a number on the motor.
von
Antwort hinzufügen
David wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 35
Insgesamt: 1,623
