Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
iPhone does not charge and there is water damage - how to fix?
My iPhone does not charge with most cables (sometimes it works but very rarely) and the battery dies very fast. I send it in because it was still under warranty, but they sent me this picture to show there is water damage (so they can’t repair it).
Is the damage irreversible? Can I fix it myself? Which guides should I follow: change the battery, the docking station, what to do about the water damage?
Thank you!!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Apple’s water detectors trigger even when there was no liquid but a really high humidity. Basically, it’s their way to say “F you!” and make you buy a new phone or parts that worth just as much as a new phone. Just send it to third-party reputable repair shop and ask them to take a look on your 5C’s USB port, if replacement (that you can make) won’t help or you’re afraid to go deeper (that can also needs to be done in some cases).
And check more cables on your phone or those cables that didn’t work on other devices. If they still don’t work, then it’s just straight bad luck and you got faulty cables. Is they work as usual (it also means that they charge as fast as usual), then you might consider replacing USB port.
About those practices: https://www.youtube.com/watch?v=_XneTBhR...
Instruction on replacing Lightning port: iPhone 5c Lightning Anschluss und Kopfhörerbuchse ersetzen
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thank you for the help!
von
Antwort hinzufügen
Myrah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 53
