Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
iPhone 6s | Ribon Cable has been cut
While I was replacing the battery, the connecting black ribbon has been cut. I think it was for the front camera and the speaker. You can see from the photos.
Is that enough to replace the front camera/speaker?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
do you mean cable or ribbon, if you mean the cable that goes from the charge flex then no you will need to buy a new charge port, any of the ribbons are sold seperately
War diese Antwort hilfreich?
Bewertung 2
There may be someone selling this cable, however the upfront equipment and process cost needed to replace the cable alone will exceed the cost of the phone, therefore it is not economical to buy just one cable unless you are refurbishing screens commercially.
Bewertung 2
Remove the camera & speaker flex. It looks like it could be that one.
As the smaller one is for the home button, and the other one which isn't cut, I think is for the LCD.
If that part of the cable is from the camera flex, then you need a new front camera.
If it's not, then you'll need a new LCD.
You won't be changing the LCD flex without any proffesional refurbing kit.
Bewertung 1
1 Kommentar:
Dear Duane,
I have added a new photo after removing the camera and speaker. It seems the ribon is for the camera.
Is the phone running without (unplugged) camera and speaker?
von
Dear Daniel,
Thanks for your reply.
I think it is ribbon, please find the below screen shot.
I found some parts on the spare parts categories. Is the below link is it for my problem?
iPhone 6s Test Cable for LCD Screen and Digitizer
iPhone 6s Test Cable for LCD Screen and Digitizer Bild
Produkt
$14.99
Bewertung 0
2 Kommentare:
it could be an lcd ribbon in that case which means you may need a new screen otherwise it could be to do with the front camera/speaker or home button ribbon
von
The front camera ribbon cable needs to be replaced. That is torn in the picture you've shown. Screen cables are OK
von
Antwort hinzufügen
nzmturkan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 513
