Zum Hauptinhalt wechseln
A series of 40 inch LCD HDTVs by Sony.
20 Fragen Alle anzeigen
Sony tv no picture has sound
Immediately after I turned power on to my Sony xbr-75x850e tv Heard a small pop. Sound came on normal but no picture. DTV box light on. TV light on. Does not feel hot. No burnt smell. Less than 1 year old
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@megh27
disconnect all inputs. disconnect the power cord. Hold the power button depressed for about a minute, then connect one video source. Try something like a game console or a DVD player (just in case the issue comes from your DVR box).Right now it sounds like it could be a backlight issue as well as a video issue, With the TV on and sound working, shine a flashlight at an angle(in a darkened room) against the screen. If you can make out shapes and silhouettes, it is a backlight issue. Could be a bad backlight array or bad power board. If you do not see anything it could be a bad main board or T-con board. If that does not work you may have to replace the back on your TV and check a few things. You will need a meter for that and it will help if you post some good pictures of your circuit boards with your question. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Megan Harris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 11,204
