Zum Hauptinhalt wechseln
Shark Ultimate Professional 1800-watt clothes iron, identified by model number GI505.
Why does my shark iron temp setting light keep changing?
My shark iron is only 4 months old. When I set the temperature control light, it will not stay set. It runs up and down and may even turn itself off.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
My iron does the same thing and has done this since Day 1. The steam doesn’t always work either. I thought it was something I was/wasn’t doing right. I’ve had my iron for over a year.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @littleproblems ,
It appears that there may be a problem with the temperature sensor in the iron.
There is a 12 month manufacturer’s warranty on the iron.
As the iron is only 4 months old, I suggest that you contact the manufacturer as per the details in the manufacturer’s warranty statement that should have come with the iron, as to what to do to make a claim for a manufacturer’s warranty repair or replacement.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Sherall wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 1,456
