Zum Hauptinhalt wechseln
Die dritte Ausgabe des 10.1" Galaxy Tabs.
126 Fragen Alle anzeigen
Broken cable clamp on Orange flat cable
After replacing the battery on my 10.1” galaxy tab 3, the little bar clamp on the orange cable broke and the cable does not clamp down in the slot. Swiping the screen is now erratic and often not even happening. I guess this is the problem as I have changed the battery before with no ill effects. Is it repairable?
Holding the cable in place with tape does not help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare
Can you add a photo
von
Thanks for your quick response Daniel, can't seem to paste the copied photo. if its any help the little bar was a brown colour and snapped in the middle and both parts disappeared.
If you know how to post the picture I have it.
von
You can edit the post and add a photo. Click on options and edit
von
Sorry Daniel this isn't working for me. I'll report back after the white tak attempt
von
https://www.dropbox.com/sh/axs768psmbm9m...
I have dropped the photo into here, hope it helps because the white tak solution has not performed
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
im guessing its this you mean dennis. yes they can be repaired but you need the proper tools to replace it. i have only done 1 on a tab e before
War diese Antwort hilfreich?
Bewertung 2
13 Kommentare:
looks like that. I am not hopeful for a good outcome.
It is taking a long time to charge now and as it is over 6 years old I feel it's race may be almost run......
von
the charging issue could be a bad charge port or the charging chip is going bad
von
Are the parts easily obtainable?if so from where? it couldn't hurt to change the charging slot and maybe all the flat cables.
von
should be available on ebay
von
Cheers Daniel, I will report back any success
von
8 weitere Kommentare anzeigen
Antwort hinzufügen
Dennis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 714
