Zum Hauptinhalt wechseln
Samsungs Flaggschiff Smartphone mit Stift und Nachfolger des Note8 kam im August 2018 auf den Markt. Es verfügt über ein 6,4 " Display und bis zu 512 GB integriertem Speicher.
Touch screen recognizing finger only s pen on note 9
I was replacing a screen on a note 9 and when I switched the motherboard and other components to the new screen and powered it on the phone would not recognize me touching it with my finger so I tried the s pen and it worked fine so then I switched everything back to the old screen thinking that it was just a defective part and it still wasn't working. I tried cleaning off the connectors for the screen and resetting the phone and neither worked. Any help would be greatly appreciated. Thank you in advance.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I thought so too but I put all the components back onto the original screen and the touchscreen didn't work on there anymore and I also tried different screen and didn't work on there either
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
probably just a faulty screen
S pen is a completely different part of the display to the digitizer, it’s the large rectangle flex near the lcd connector.
unless you buy the screen from samsung or from a new phone they are all refurbished, so probably just a dud screen
War diese Antwort hilfreich?
Bewertung 1
Did you ever get this fix? I'm having the same
Bewertung 0
1 Kommentar:
Also, would something like that be under warranty?
von
Antwort hinzufügen
Poop mcgee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 43
Insgesamt: 2,606
