Zum Hauptinhalt wechseln
2.4GHz, 2.7GHz, oder 2.8GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
274 Fragen Alle anzeigen
No display and no backlight
Hi,
I’m have problem with my Early 2013 MacBook Pro it has no backlight.
Tried with knowing good display, no image at all on external display.
Backlight Fuse working fine, but there is small IC chip shows small burning
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Can you give us some background information on what happened to the system to start with.
To be clear you don't see anything on the external display
von
Suddenly display goes off and not respond
Tried reset SMC and PRAM
Checked Backlight fuse is ok with Buzzer
Tried with knowing good display issue still occurs ?!
Tried with External there is signal and working normally on external Display!
as you can see in pic , like burning on this crystal iC !!
von
Einen Kommentar hinzufügen
1 Antwort
Q3880 - SI8409DB - P-Channel 30 V (D-S) MOSFET
I think you need to dig deeper here as this likely was damaged by something else going bad on your logic board. I would get the schematics and board view drawings so you can properly diagnose the problem.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mohamed Ghaly wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 280
