Zum Hauptinhalt wechseln
A1150 will not charge. Can one replace the charging circuit?
I have a used A1150 (eBay) and it has never been able to charge at all. I followed all the troubleshooting guides from Apple's tech pages and went to my local Apple tech store. They switched the Magsafe and swapped the battery. Their battery worked fine but the Magsafe charger still did not work (it holds a very dim green light when attempting to charge). They said it probably was not the logic board but the actual charging circuit. What part(s) would I need to replace the charging circuit? can one replace the charging circuit without soldering?
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Do you mean to say they swapped the left i/o board? (the part with the magsafe board)
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
yes, the charging circuit should be on the left I/O Board, you can find the repair instructions here - replacing it does not involve soldering.
War diese Antwort hilfreich?
Bewertung 1
They only switched the Magsafe adapter not the left I/O board. Sorry for not qualifying that. @rab777hp
Great tutorial @bac. i will grab a few tools and find a replacement left I/O board. Thanks!
Bewertung 0
Are you sure it's not the battery? The computer end of the Magsafe on this model of Macbook Pro glows red when the battery is depleted and green when fully charged.
Bewertung 0
My bet would be the Left side I/O board. Not difficult to replace, but parts getting hard to come by!
Bewertung 0
Antwort hinzufügen
Steve 10 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 5,996
