Zum Hauptinhalt wechseln
Das OnePlus 6T ist ein Android Smartphone von OnePlus. Angekündigt wurde es am 29. Oktober 2018 und erschien dann am 6. November 2018.
I need to clean the speaker holes
Hi every one, i have one plus 6T, i have spoiled a hot liquid candle wax on it, and i was able to remove the damage from the screen (thanks to the screen protector) now am left with only 3 holes for the speaker to listen from (the rest is blocked with the wax), i have tried to apply some heat from the hair dryer with no luck, what do you think is the best way to solve this issue ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Hi Raving,
thank you for your answer, i had tried to do this but it didn’t fix it, even i applied heat using a hair dryer then i used the needle, but the surface area is so small that the wax will be hard again while am trying to apply the push through the needle
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Try putting the phone is a ziplock and use a hair dryer, the wax should flow out. Alternatively follow the teardown guide ( skip removing the motherboard) and clear out the wax form the inside. OnePlus 6T Teardown
War diese Antwort hilfreich?
Bewertung 1
Try using a needle or a slim pin to clean the speaker holes. If you are careful, you can just take out the wax without damaging anything.
Bewertung 0
I usually wrap a glue-dot around a cocktail stick and use it to clean the dust out. I find that glue-dots are just the right consistancy to pick up dust, but still firm enogh not to get clogged in your phone.
Bewertung 0
Vacuum cleaner and a stiff toothbrush. Be careful not to push the wax further inside and damage the speaker.
Bewertung 0
Antwort hinzufügen
Abdullah Al Rawi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 8,036
