Zum Hauptinhalt wechseln
1,8 GHz Dual-Core Intel Core i5 (Turbo Boost bis 2,8 GHz) mit 3 MB geteiltem L3-Cache
371 Fragen Alle anzeigen
New battery says "Service" after just 4-5 months
Hey.
I have some problems with a mid 1466 macbook air and battery.
I replaced it with a brand new one, but allready after a few months it starts saying “battery needs service”.
Does it need a recalibration or SMC reset?
Anyone else have experienced this?
Best
Update (03/21/2019)
Hi Dan. Thanks for the answer, i got a hold on the macbook now. Here is picture with adaptor plugged in. Right now, if I remove power the macbook LCD goes black.
picture of coconut
Update (03/21/2019)
I have replaced battery and reset SMC. Shift ctrl alt power for 10 sec. Charger goes from orange to green to orange, as it should to confirm the reset.
Right now the Mac battery % and Coconut does not seem to agree the current charge in %
coconut after battery replacement
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
Install this gem of an app CoconutBattery take a snapshot of apps window with the MagSafe plugged in and a second with it disconnected, post both here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
I wouldn't worry about the discrepancy. The OS value is just updated faster than what CoconutBattery is able to.
Other than that is the system stable?
von
Einen Kommentar hinzufügen
1 Antwort
Try recalibrating the battery. It probably is thinking it’s the old battery, even though you replaced it, so a recalibration should help. If not, try removing the battery, powering on the MacBook, shut down (safely!), and reinstall battery.
Good luck!
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thanks for answer. :)
Callibration = charge to 100% and leave plugged in for 2-3 hours more. drain battery and leave for 5 hours min. then charge full again?
Best
von
Antwort hinzufügen
Anders Laursen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 216
