Zum Hauptinhalt wechseln
Die größere Ausführung von Samsungs zehntem Smartphone-Flaggschiff ist mit Android 9.0 (Pie) ausgestattet. (Erscheinungsdatum: Februar 2019).
107 Fragen Alle anzeigen
From whee I can buy the back panel for galaxy s10 plus?
i want to buy the back panel for galaxy s10 plus cuz i broke mine .
and onther q . if i replace it . is the water resistant will go away ?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
As far as I know, there aren’t currently any replacement glass casings on the market. It’s a very new phone! You’ll just have to be patient for suppliers to get some stock, and maybe consider a case…
It most likely won’t be water resistant after a replacement, but if it’s cracked it definitely isn’t water resistant anymore anyways.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
ubreakifix seems like they have parts in stock. Not something you can do yourself but if you need it fixed, definitely an option.
von
You can replace the back glass yourself, but remember, heat is your best friend! totally not something that jerryrigerverything said ;p
von
We have guides for the procedure! Follow this guide: Samsung Galaxy S10+ Rückabdeckung tauschen
von
Mobile Defenders has the back glass.
It will become less water resistant depending on the type of adhesive and type of way you seal up the back.
Bewertung 0
you can buy a LUVSS back glass from amazon with camera lens and full set tools kit.
Bewertung 0
Antwort hinzufügen
molhamstar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,993
