Zum Hauptinhalt wechseln
Released September 2016. Identified by Model No. SM-G610
164 Fragen Alle anzeigen
Why is my back button not working
What causes some keys not to work sometimes? I discovered the return/back button on my phone wont respond to touch often times. This is frustrating because it makes using an app that requires a return function difficult.
Ist dies eine gute Frage?
Bewertung 6
3 Kommentare
The same with my phone return button didn't work but when I tried to reset it works it features not the factory reset it work for several minutes only, then not working again, seems there's time elapse program to lock. I tried all options even the factory reset. The same happened working for several minutes only.
von
Can anybody suggest to solve this problem without going to any phone tech?
von
لقد سقط هاتفي مرات كثيرا علئ الارض
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Do you have a screen protector on the phone? If you do it could possibly just be a case of a bad cheap screen protector. If not it could be an actual issue with the buttons themselves. Or it could just be phone lag if they eventually do respond or if the phone freezes when you press them.
Hope this
War diese Antwort hilfreich?
Bewertung 1
I had this problam too, when i opened the phone there was a little water damage.
Are you sure it does not have any water damage…
Bewertung 0
My back button don't work at all
Bewertung 0
Antwort hinzufügen
Chinwe U-O wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 5,658
