Where is the fuseable link for the ignition
where is the fuseable link between the battery and the ignition switch
Ist dies eine gute Frage?
I know that there is a 100 amp fuse that is bolted in place. There are access covers on the side of the fuse block that allow you to remove the 2 8mm-headed bolts holding it in place. Here is a Video that will show you the location as well as how to change it.
So the main fuse is under your hood in the fuse block. I attached a few pictures so you know what to look for. The red circle is the main fuse the yellow you can ignore since that is not your problem. They are for the EGI. Also attached an image for all of your fuses. The manual says to remove the fuse disconnect the negative battery cable.
Remove the main fuse block cover, remove the main fuse block mounting nuts. Remove the MAIN fuse mounting bolt to remove the fuse.
Hope this helps with your problem. Good Luck
War diese Antwort hilfreich?
It should be under the hood, in the fuse box. It isnt a small fuse like you would change normally, it is a larger 50A one probably.
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 33
Insgesamt: 4,717
