Zum Hauptinhalt wechseln
Die Nintendo Switch ist eine tragbare Spielekonsole, die auch mit dem Fernsehgerät verbunden werden kann. Sie wurde am 3. März 2017 veröffentlicht.
704 Fragen Alle anzeigen
Nintendo switch not charging after port replacement
I recently replaced my nintendo switch’s USB-C port and tried charging it and nothing just a black screen, then i got a nintendo switch battery which was fully charged and plugged it in and powered it on and still the black screen, any ideas as to what might be causing this? any help would be greatly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
It might be a motherboard problem
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Most likely one of the chips on the motherboard is faulty. Could be the M92T36 chip and or the P13USB chip or possibly something else but those are the two most common. The easiest way to diagnose those is by looking for shorted capacitors near the chips like I show in this video: https://youtu.be/EP65185uGiA
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
Hi TronicsFix,Thank you for replying, I believe i have faulty capacitors, Is there a specific capacitor i am supposed to purchase? Any help would be greatly appreciated!
von
@migjav It's highly unlikely that the capacitors are faulty. 99.9% of the time it's one or more of the IC's on the motherboard
von
Oh I see, but just in case could you provide me with the type of capacitors I am suppose to purchase if it does turn out to be a faulty capacitor. Thank you.
von
@migjav I don't know what they are. I've never had to replace one...even if I did I'd just take it from a junk board. Sorry
von
Hi seen your comments an IV got little bit different I replaced c port Nintendo switch lite it don't turn on I put charger in an turns on I can hear it working but have a black screen I'm just getting I to soldiering an not sure we're I went wrong thank u
von
Antwort hinzufügen
Miguel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 10
Letzte 30 Tage: 39
Insgesamt: 2,949
