Zum Hauptinhalt wechseln
Die Wi-Fi Version des iPad Air mit der Modellnummer A1474 ist in Space Grau und Silber erhältlich. Sie enthält einen A7 Prozessor und ist mit 16, 32, 64 oder 128 GB Speicherkapazität erhältlich.
299 Fragen Alle anzeigen
Recycle parts from unbootable iPad.
sorry my english poor :(
I have two failed iPad Air.
One is booting normally, but the iCloud locked. (Hereafter, "X ipad".) The other one does not have an iCloud lock, but can not boot. (Hereafter, "Y ipad".) It is a completely black screen. Only dfu mode entry is possible, but recovery has failed in any way.
"X iPad" is an LTE model, and a "Y iPad" is a wifi model.
So I want to move the parts from the “Y iPad” to the “X iPad”. I want to know what parts to move. I heard that NAND and WIFI IC should be moved, but are there any other parts that need to be moved?
I have BGA soldering skill and equipment.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You would have to move also the EEProm and of course the SOC (Cpu). Good luck with the job, hope you will succeed, not an easy task.
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
NAND
WiFi IC
EEPROM
CPU
Do I have to move the four parts listed above?
von
Thanks for your reply. I'm afraid, but I'll try.
von
@wellbinn That's the right approach, I'd be afraid too. Such big ICs replacements usually go well only on older youtube clips, but you don't have much to lose..keep us posted :)
von
There’s a resistor (r1506 on a1475)you can remove from the LTE ipad that will disable LTE and make it Wifi only but it’ll bypass the icloud lock. That would be your best course of action imo
Bewertung 0
2 Kommentare:
As far as I know, that method has been blocked since ios11....
Please point out if it is not true.
von
@wellbinn he lives in the past but he doesn't know it yet, or he's wasting time..
von
Antwort hinzufügen
wellbinnn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 86
