Zum Hauptinhalt wechseln
Leapster LeadPad Explorer Child's Educational Tablet.
Water spilled , stopped working.
Bought that device for my son in New Zealand, we moved to Kuala Lumpur, Malaysia, some water spilled over it and stopped working, I couldn't find anyone who can repair it in Malaysia, any advice??
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @hawk911
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the tablet’s operating design and could damage the components.
First do not turn on (or try to turn on) your tablet and then you need to disconnect the battery as soon as possible from the tablet to minimize any further damage.
Then you need to dis-assemble the rest of the tablet and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the tablet might possibly work correctly again.
Here is a link to the ifixit Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections guides. The comments under the guide are helpful as they tell how to gain access to the internal components etc
If this process seems too daunting, take your tablet to a reputable, professional electronics or mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair. Surely there must be repairers who do this where you are?
If you decide to do this, do it sooner than later.
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
Thx jay, I already done that , still won't work.
von
Hi @hawk911 ,
If it gives no signs of life even when just trying to charge it then obviously there a hardware problem.
Without a schematic or any signs of obvious damage, e.g. burnt out components, it will be difficult if not impossible to fix.
You may be able to find a replacement motherboard by searching online using the board number that is printed on the board but just searching for "Leapster LeadPad Explorer motherboard" gave zero results.
von
Thx again jay, it seems there's no solution as leapfrog seems to be the worst company ever, no Service centers for their products.
von
Hi my daughter's leapfrog fell into water n 2 years later it works but the brightness is very low and we can't see anything what do I do
von
@Ayabonga Nyawose
See the Chosen Solution above.
The tablet has finally succumbed to the effects of falling in the water
von
Antwort hinzufügen
Mason wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 34
Insgesamt: 1,591
