Zum Hauptinhalt wechseln
The Fitbit Alta smart wearable by Fitbit was released in 2016. It features a tap-activated display screen that is slightly smaller and thinner than comparable models.
20 Fragen Alle anzeigen
Fit bit exclamation and no charge
Fitbit doesn't show anything but an exclamation mark. When off the charge port it is dark.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
it still shows the exclamation mark with the battery sign. I am trying to change profiles. please help!
thanks.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The exclamation mark usually means one of two things. You either waited too long to recharge your Charge and the battery is fully depleted. Or else an error occurred during a firmware update, in which case restarting your Charge and leaving it plugged in afterwards will cause the update to resume and complete.
How to Reset : Press the button on the charging cable 3 times within 8 seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into the computer. 8 seconds after the first button press, the Fitbit logo appears on the tracker's display. This indicates that it has restarted.
War diese Antwort hilfreich?
Bewertung 6
4 Kommentare:
Thank you so much !! It is charging!!
von
no button on the charging cable.!
von
Is there any way to have the Fitbit work again if I waited too long to recharge and battery is depleted?
von
No button on versa 2 charging cable.
Mine has battery sign with exclamation mark2023, always charged ok. Now can’t sync as won’t find watch
von
check this video it may help you to using your galaxy fit '''https://www.youtube.com/watch?v=g223JepU...
don’t forgot to say thanks
Bewertung 0
My fit bit charge to is your not exclamation sign when plugged in to chargeMy fit bit charge to is your not exclamation sign when plugged in to charge
Bewertung 0
Antwort hinzufügen
Stefanie Franco wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 61
Insgesamt: 42,280
