Zum Hauptinhalt wechseln
Das Huawei Mate 8 kam im November 2015 mit Android OS v6.0 auf den Markt. Das Telefon hat eine Bildschirmdiagonale von 6 Zoll und ist mit 32GB Speicher/3GB RAM oder 64GB Speicher/4GB Ram erhältlich. Die Rückkamera hat eine Auflösung von 16MP, die Frontkamera 8MP. Das Huawei Mate 8 hat ebenfalls einen nicht entnehmbaren Li-Po 4000 mAh Akku.
15 Fragen Alle anzeigen
touch screen not working after lcd screen replacement
after lcd screen replacement touch was working fine but after few hours it stop working and then tried with other new screen replacement but touch screen not working but display is fine
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare
hi
I have this problem too, in the top of the lcd socket, some parts of resistants has been breacked
but i dont find this parts to reinstal them and exactly dont know this problem directly affected to touch or not.
von
How can solve this
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If the screen was an cheap-repleacement part then it could be not suitable for your device. The good practice is to manage a hard reset of your phone after any replacement in order to get a new drivers adjusted to your component. Try that and then you should consider an PCB damage - not only the connector but whole ICs itself. The first thing that goes off when some one not provided goes into the device is an backlight IC, but in your case it could be just touch circuit.
Try a new display after an hard reset of device. Then go back to this forum and get better answer than mine.
Ps. After reading your post over again I would suggest to check for water damages. If the screen stops working after few hours it could be some dirt/corrosion on the motherboard near chips/capacitors
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
darshan kumar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 22
Insgesamt: 9,130
