Faulty keyboard or pcb
Hello everyone,
I have MacBook Pro as mentioned that hasn’t been working couple years. I finaly decided to try to repair it.
The issue started appearing with keyboard problems the O key and V key started to acting up, later on the space bar. Then the power button worked only sometimes, but now I can’t turn the laptop at all.
I googled a bit, found some advice, press some buttons before start, disconnect the battery and reconnect which should start up the system, nothing worked.
So I just wonder wether there is a way to diagnose if the problem is the faulty keyboard, logic board or both …
Would appreciate any help.
Thank you :)
Update (05/05/2019)
Thank you everyone, especially to mayer - very helpfull reaction. I can confirm it’s probably keyboard water damage as you mentioned (laptop start up when I disconected battery and hooked up the charger) - no moisture spilled, but I realized it happened after I left my laptop in basement over night with high humidity. Will buy new upper case and try to use my DIY skills :D - looks a bit scarry but it’s nicely described.
Thank you again and have a nice rest of your weekend.
Radim
Ist dies eine gute Frage?
3 Kommentare
Hi Radim
I guess this video can give you some information to check on your computer.
Macbook Pro - Non functional power button, how to power on
von Augustine
Hi Austine, thank you for your quick respond. hah Ive been searching but didnt find this video, will try today after work and update here.
thank you very much, Radim
von Radim Čapák
Radim, Just click on the blue link to open the video.
von Dan
