Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
797 Fragen Alle anzeigen
iPod 5th generation and iPod classic LCD interchangeable?
I got a broken iPod 5th generation from a Friend. The Display is broken. Another friend has a broken iPod Classic with a broken Hard Drive. I have read that the iPod Classic Display should be thinner (But I am not completely sure as no source was mentioned), so I wonder if the Display from the iPod 5g can be replaced with that one from the classic?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
Did you try it? Have you been successful?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
JeriC, if i remember right, besides being thinner, the cable and connector are also somewhat offset, so that may cause you some grief. Since you have immediate access to the display, just give it a try and see :-) On the other hand, a display for the 5th gen is not that expensive and an easy fix. Good Luck
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thank you! And yeah, I know that they are not that expensive, but I don't know if there are other parts broken on that iPod (the Display is obvious ;) ) and I thought that I won't buy a Display just to realize that the logic board is also broken.
von
Antwort hinzufügen
JeriC wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,298
