Ipad shuts off at 100%
Hello! So, my iPad has been doing this thing when I charge it at 60% overnight and by the morning its “dead” even though it’s at 100%. It will power up for about a minute, if plugged in, and show 100%. But, if I unplug it within that one minute it will immediately shut off and “die”.I connected it to coconut battery a couple days ago and it showed what’s in the image.
I also used a battery app that I downloaded from the App Store and it said the design capacity was at 30% but coconut says 80%. I don’t get that. But, is it time that I replace the battery or could it be something else?
Ist dies eine gute Frage?
5 Kommentare
iPad Pro Shuts down when charged to 100%
SOLUTION FOR ME- once i pad is charged 100% a- enter your passcode- FIRST thing, put it onto AIRPLANE MODE, put BLUTOOTH OFF and even put off WiFi if possible and use ipad for 2-3 minutes.
Then only start using ipad with Blu-tooth, cellular or WiFi functions.
(IMO might be, as soo. As the system starts, it tries to hit blutooth or cellular functions and it might be impacting the battery function)
von pkur
I know this is over a year old, but try calling Apple and diagnose it to see if your battery is at 80% health according to them. If it is, they’ll replace your entire iPad with a brand new one for $99 plus tax out of warranty. I highly recommend if you still enjoy your current iPad model and want to keep using it without a problem.
von Carlos Gonzalez
Mine needed rebooting a few times before it stayed on after a 100% charge and showed the plug it in graphic when I tried to turn it on. But when it stayed on the battery was fine for a few days so clearly not a battery issue. The fix is book an appointment with an Apple genius at an Apple store and say the recent update has screwed the battery firmware calibration. The appointment arrives by email suggesting back it up and make sure it’s up to date (but auto updates was on). So plugged it in for a really long update installation (so long I had to cancel my appointment) but surprise surprise problem fixed!!
Apple trying to sell more iPads again!
von Malcolm Short
pkur solution wprked for me thanks Peteralb
von Peter Lindsay
I have a generation 1 IPad Pro that had the same issue. After reading most of the comments I tried something new and it works perfectly. I bought an outlet with a timer and plugged my charger into it. I charge my IPad for 2-4 hours, then the timer shuts off the charger. The time that the charger is off seems to make a difference. The issue has not happened for 2-3 months, had been happening 3-4 times per week. I bought the outlet timer on Amazon for $13.
von C5guy98@gmail.com
