Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Screen is unresponsive after a drop
I dropped my phone on the ground yesterday, and the LCD faded out. I figured it was just a screen problem, but I replaced the screen twice, and neither worked. I was able to put it into recovery mode after the drop, but I do not want to restore it yet because I do not believe my notes are backed up, and I am not sure if that will fix the problem. I was wondering if anyone has a hardware fix to this problem.The phone hasn’t had any problems before, and the drop did not do any exterior damage. It landed face down, and the screen did not crack. I do not think I will be able to recover my notes if I can’t fix my phone because they are not backed up, and I can not trust a computer from my iPhone to export them off of the phone. Thanks-Alec
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The only thing I can think of is to check the fpc connector on your motherboard and see if it is intact, it is possible that the dro could have dislodged a pin and that may be causing your problem. Sadly if this is the case, you'll have to get a new fpc connector soldered on by a professional.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
You might be on to something. The top right corner where all of the connectors are at was very hot when I touched it while it was charging. I will get that checked out and let you know if that is the problem. Thank you.
von
Antwort hinzufügen
Alec Thompson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 244
