Zum Hauptinhalt wechseln
Erschienen im Juni 2017 als Nachfolger des Microsoft Surface Pro 4, ist er auch unter dem Namen Microsoft Surface Pro 12,3" bekannt. Die Modellnummer ist FJT-00001.
Bad battery, need to replace
Hello. I think I may need to replace the battery in my Surface pro 2017 if it gets any worse. Two years after I bought it I only get 3 hours of battery life. I see you have a surface pro 4 battery replacement video but I can’t find any specifically for Surface Pro 2017. Do the video and the tools for the Pro 4 also work for the Pro 2017? Any advice would be appreciated. Thanks!
Ist dies eine gute Frage?
Bewertung 5
2 Kommentare
My customers surface only turns on when connect to charger
von
I bought a new battery ($50+) then cracked the screen ($200) and then broke the LCD touch screen connector ($10) which I am waiting for. So I’m in it for $260 to “change the battery.” Couldn’t find a place that would do it because the screen tends to crack. Not sure what I would do better next time but you may factor these costs in in making your decision to replace vs. buy new one. I had the same experience as you as far as battery life. I ended up buying a new Surface Pro 7 and am going to use my old one as a back up.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@ilikegreen I would suggest to follow the guides and teardown from here After that proceed carefully the same way as the Surface Pro 4.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Thanks for the advice.
von
I do not see a battery replacement guide help!
von
Antwort hinzufügen
Richard Paulino wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 24
Insgesamt: 1,887
