Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1203 Fragen Alle anzeigen
Maximum HDD size supported by MacBook Penryn
I'm looking at buying the 750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit for my MacBook but I read that the maximum size supported by this model is 500 GB.
Is it true? Does it mean I need to partition the HDD? Or it's supported and I won't have any issue?
Thanks in advance for any advice!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I doubt that; 500GB was probably the biggest drive available at the time that was written. 750GB should be fine, one of my favorite Mac upgrade sites lists that 750GB drive as an option for your exact model.
War diese Antwort hilfreich?
Bewertung 2
It's not the size of the GBs of the drive but the physical size limitation. You'll need to stay with a 9.5 mm standard drive. The new 12.5 mm drives and larger will not fit in your machine. I would go with a 7200 rpm drive rather than a 5400. Here's a couple of good ones:
[verlinktes Produkt fehlt oder ist deaktiviert: IF107-099]
http://eshop.macsales.com/item/Western%2...
Bewertung 2
1 Kommentar:
I'd take the seagate over the western digital any day, personally. WD drives fail too often.
von
Antwort hinzufügen
andreamonni wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,969
