Zum Hauptinhalt wechseln
Repair guides and support for your Philips TV.
242 Fragen Alle anzeigen
Lines show on TV then it powers down.
These lines appear anywhere from seconds to minutes after the TV is powered on. Then it shuts off. Any suggestions for a DIY fix. I work for a hotel and we don't want to have to pay a TV repair company.
Ist dies eine gute Frage?
Bewertung 1
5 Kommentare
Hey Grady, does the TV do this on all inputs? I'm curious if this might be an issue with the cable. Although the TV powering off makes me think otherwise.
von
Only on the TV input. And when I change inputs I can no longer go back to TV.
von
@acraftyhippo what model is your TV?
von
The model is 32HFL5860D/27. It's a hospitality TV. The issue only shows on the TV input for coaxial. If I change the input the problem does not persist but I cannot return to the TV input.
von
Out of curiosity, @acraftyhippo, have you tried using a different coax cable, and with that a different wall port?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@acraftyhippo could be a main board, t-con board or even panel. I’d be looking at the t-con board first. Explain this a bit better “Only on the TV input. And when I change inputs I can no longer go back to TV. “ That sounds like it does not show on other video input sources?
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Grady wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 228
