Zum Hauptinhalt wechseln
The Iconia One was released in October 2016 by Acer. With a 10-inch screen, it has dual-band wifi, 24GB of storage, and a long battery life. Model number: B3-A30
13 Fragen Alle anzeigen
Is the screen digitizer attached to the LCD?
Wondering if I can just buy the LCD alone, or have to get the LCD+digitizer assembly, as the touch still works fine, just the LCD is cracked
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
tipoo the digitizer and the LCD are separate pieces. You can replace one without having to replace the other
Acer Iconia One 10 B3-A30 Repair Screen Replacement
War diese Antwort hilfreich?
Bewertung 2
Yes, I do believe this tablets digitizer is attached to the LCD. It would be recommended to replace them both rather then try to do an at home adhesion if that is the case. I attached a screen repair link below and it does show two pieces at the end. however I cannot tell if the white frame is a digitizer or just a cover.
Might want to drop that author a message.
Bewertung 0
Antwort hinzufügen
tipoo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 107
