Zum Hauptinhalt wechseln
HP’s 2-in-1 convertible laptop released in April 2015, identified by model number: 13-4003dx.
9 Fragen Alle anzeigen
Screen replacement ribbon too long, how to fix?
I just replaced the screen (digitiser and LCD) of my laptop. The screen and touch is working perfectly, but I haven't been able to glue it back down with adhesive, as the ribbon sticking out the bottom, that I plug into the board that controls the touch, is a bit too long, so when I put the screen into the casing, the bottom part sticks up and won't sit flush. Can I bend this ribbon to give it a kink so the screen lies flat? Or do you have any other tips/tricks?
Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Look at the original screen and bend the cable in the exact same way. The original should have same sized cable but it’s usually bended in a way for it to fit in flush.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Calypso McDonnell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 70
